Amateur Radio Weekly 23MAR2024 - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: NEWS (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=23) +---- Forum: Radio News (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=54) +---- Thread: Amateur Radio Weekly 23MAR2024 (/showthread.php?tid=1159) |
Amateur Radio Weekly 23MAR2024 - Richard VE3OZW - 2024-03-23 ![]() Issue 324 March 23rd, 2024
Top links Open HT surgery gives cheap transceiver all-band capabilities Watch out, Baofeng; there’s a new kid on the cheap handy talkie market. Hackaday Ultimate Direwolf TNC installation guide For Windows and Linux. The Modern Ham Operators criss-cross country airwaves A nationwide event occurred recently involving tens of thousands of North Americans. The Community News FCC to require two factor authentication for CORES Beginning March 29, 2024, multifactor authentication will be implemented. ARRL What became of Marlon Brando's wonderland on the sea Brando's Tetiaroa Beach bungalow, circa 1979, is filled with his Ham Radio equipment. LA Times TinyGS: The Open Source Global Satellite Network An open network of ground stations distributed around the world. EI7GL 868Mhz ground plane vertical antenna A neat little ground plane vertical antenna for the 868Mhz ISM band. M0AWS 50 things you can do with a software defined radio All you need is this simple USB dongle and an antenna kit. blinry This space physicist uses radios to study eclipses Nathaniel Frissell works with Amateur Radio operators to learn more about our atmosphere. ScienceNewsExplores The GM3OXX Oxo Transmitter The two-transistor transmitter. AA7EE Video Go Kit Challenge 2024 Check out some AWESOME go kits. Tank Radio Flight over Glaciers of the Olympics With 2M simplex operations. W7NY Hamvention bound For the first time, I'll be driving up for Hamvention in May. I'm attending as a member of the press and my current thinking is to attempt a number of short-form audio interviews with interesting orgs, Hams, vendors, etc., which will be posted both here in the newsletter and on the daily site. I'm also having stickers made up, so hunt me down if you'd like one. Hope to see you there! 73 K4HCK ![]() Did you receive this email as a forward?
Amateur Radio Weekly is curated by K4HCK. Do you have an interesting item to share? Email us! Thank you for reading. 73 |
