Amateur Radio Weekly 09NOV2024 - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: NEWS (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=23) +---- Forum: Radio News (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=54) +---- Thread: Amateur Radio Weekly 09NOV2024 (/showthread.php?tid=1319) |
Amateur Radio Weekly 09NOV2024 - Richard VE3OZW - 2024-11-09 Issue 355 November 9th, 2024
Top links Zinc creep and electroplasticity Why Arecibo collapsed. Hackaday What's new at Digital Library of Amateur Radio & Communications The 50 MHz DX Bulletin, the Ohio/Penn DX Bulletin, Numbers & Oddities Newsletter, The Telegraphic Journal and Electrical Review, and more. K6KJN & Zero Retries HamSpace.me: The social media alternative for the Ham Radio Community HamSpace.me is looking for a new maintainer. Contact KI6DTC if you can help. HamSpace.me Open Source FT8 transceiver A highly portable stand-alone FT8 GUI Transceiver. WB2CBA How to build a radio Using analog tech to teach kids about STEM. LAist Slinky antenna revisited It was soon discovered that connecting two Slinkys end-to-end significantly boosted the antenna's efficiency. K0PIR WKHS makes international contact with Amateur Radio Chris Singleton, broadcasting teacher and manager of the high school’s radio station 90.5 FM WKHS, introduced students to Amateur Radio. Radio World Video The haunted band workshop A presentation, review, and Q&A for proposed rulemaking to the US FCC for Restoring Amateur Radio Service use of the 219 MHz Band. Open Research Institute Inc. Radio receiver using old TV tubes Superregenerative FM / VHF radio receiver using electronic tubes PCF82 and PCL85. Perian Marcel Introducing the Faraday Cloth Antenna The Fara-J – a cutting-edge 2m-70cm Ham Radio antenna crafted from Faraday cloth. Ham Radio Rookie Did you receive this email as a forward?
Amateur Radio Weekly is curated by K4HCK.
Do you have an interesting item to share? Email us! Thank you for reading. 73 Friends of the Newsletter | View the archive | Follow on Mastodon Explore the Ham Weekly Network
annie9517@gmail.com. Press tab to insert. |
