GBARC Forum
RF Chokes for RFI Suppression - Printable Version
+- GBARC Forum (https://www.gbarc.ca/ForumBB)
+-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5)
+--- Forum: Builders (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=19)
+---- Forum: Repair Construction Questions (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=10)
+---- Thread: RF Chokes for RFI Suppression (/showthread.php?tid=1322)
RF Chokes for RFI Suppression - VA3-GUF-Frank - 2024-11-12
To all,
The presentation I gave is too big to attache or upload on the forum so the following will be a synopsis of the details from the 11 slides presented.
DIGITAL NOISE SOURCES
LED Lights                                   LED Displays / TV’s
USB Power supply chargers           Laptop Power cord
Hydro Smart Meters                     12VDC power supply
Battery Chargers                          Car 120VAC inverter
Solar Controllers
Typical recommendations at the antenna
10cm /4in. PVC wrapped in Coax band specific
     160m            28 turns
       80m            24 turns
       40m            14 turns
       20m              8 turns
       15m              5 turns
       10m              4 turns
This presentation will focus on the use of Snap on MIX-31 Ferrite of 0.25 inch inner diameter and 0.50 inch inner diameter.
Radio Station without and with Random wire Tuner
Add Mix-31 Ferrite 0.25 inch (Straight pass)
   * 1 Ferrite @ Transceiver for installed External Speaker
   * 1 Ferrite @ Transceiver for Remote Head
   * 1 Ferrite @ Transceiver for Antenna without tuner
Add Mix-31 Ferrite 0.50 inch Looped @ transceiver & @ Tuner
   * 2 x 5 looped Ferrite on Coax = 10 total
   * 2 x 1 looped Ferrite on Control cable = 2 total
Total Ferrite
0-3 Mix-31 0.25 in. ID
12  Mix-31 0.50 in. ID
Radio set up for Digital modes
Same as Radio Station with or without tuner
Add MIX-31 Ferrite 0.05 inch Looped
MIX-31 for each PC cable;
   * 1 Ferrite @ TNC/modem & 1 @ Computer
MIX-31 for each Radio cable;
   * 1 Ferrite @ TNC/Modem & 1 @ Radio
Total Ferrite
Radio Station with or without Tuner set-up requirements
4+ MIX-31 0.50 in. ID
Dependent on your radio station set-up, anywhere from a few to as many as more than 19 Ferrite may be used.
Diagrams for the placement of the ferrite can be found also in the 2 attached files showing radio station set-up cabling.
Should anyone have questions on any of the above I can be reached at va3-guf@outlook.com.
Cheers
Frank
VA3-GUF / VE0-GUF / VE0-VET
