Double Extended Zepp Antenna - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: Builders (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=19) +---- Forum: Antennas (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=12) +---- Thread: Double Extended Zepp Antenna (/showthread.php?tid=327) |
Double Extended Zepp Antenna - Tom VA3TS - 2021-01-19 This is what I have, make one for 80m, tune 160 to 10 .... 3db gain if you an get it up the magic 1/2 wavelength.. should be easy to do on 40...bonus of 3db gain broadside ...73 https://www.iw5edi.com/ham-radio/428/double-extended-zepp-antenna RE: Double Extended Zepp Antenna - VE3WI Dave - 2021-01-19 For 3783 kHz: EDZ length calculates out to 316' 8". We have 70' x 130' lots here, so I'd need some really cooperative neighbors :-) I haven't heard anyone on that VE3KCY 50.170 MHz net (or anyone else on 6m for that matter) with my 80m inverted-V + tuner. I wonder if an EDZ would work better for 6m. Only ~24', I could manage one that long. Maybe even add a reflector for some more gain (just found an article by Cebik about that very idea: http://www.antentop.org/w4rnl.001/edz.html). 73 Dave, VE3WI |
