Net Report 27 Jan 2021 - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: GBARC (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=17) +---- Forum: Nets HF , VHF (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=15) +---- Thread: Net Report 27 Jan 2021 (/showthread.php?tid=339) |
Net Report 27 Jan 2021 - Tom VA3TS - 2021-01-27 VA3TS Tom Shallow Lake NCS KO4DXQ Bob Tennessee VA3KOT John Owen Sound VE3FP Adam Elmwood VE3DGY Doug Owen Sound VE3RQY Greg Owen Sound VE3RWY Rob Owen Sound VE3GIO Larry Woodstock VE3WI Dave Port Elgin VA3EZN Jim Aurora VE3BQM Bernie HF Net VE3GIO Woodstock VA3KOT Owen Sound VE3BQM Owen Sound VA3EZN Aurora VE3RQY Owen Sound VE3DGY Owen Sound VE3WI Port Elgin VE3RWY Owen Sound RE: Net Report 27 Jan 2021 - VE3WI Dave - 2021-01-28 Good net Tom. Very pleasantly surprised by propagation last night - I was able to hear local hams on 80m, & be heard! Last few nets I've heard no one in OS at all. Frustrating when stations all over NA and even a few in Europe are booming in. In despair, I was thinking of trying a different antenna, maybe a sloper aimed at OS for a little more gain in that direction. I attached a design for a short loaded 80m dipole that I could hang off my mast. Maybe after FD... 73 Dave, VE3WI RE: Net Report 27 Jan 2021 - VA3KOT John - 2021-01-28 Dave, I use a short-loaded end-fed half-wave wire (electrically a half-wave but physically only about 75ft long). I feed it at one end through a 49:1 transformer. The coil is inserted at the quarter-wave point (~67 feet) so that the other "quarter wave" comprises the coil and a few feet of wire. It has a high-Q which makes it a little difficult to tune so I have a short tail (about 6 inches) of wire at the far end that I can adjust for best SWR. I get around 1.8:1 on the CW portion of 20m, 40m and 80m and can use it with the tuner bypassed. The SWR rises to over 3:1 on 3.783 MHz but the tuner takes care of that very easily. I would expect groundwave propagation from Port Elgin to Owen Sound; it's only a distance of about 35-40km. Solar conditions would then be unimportant. A NVIS antenna would work if groundwave fails for any reason. Regular skywave propagation would put Owen Sound into your skip zone. Are you using a vertical antenna? A vertical would launch your signal way overhead of OS. RE: Net Report 27 Jan 2021 - VE3WI Dave - 2021-01-28 Thanks John. My present HF antenna is an inverted-V about 122' long with apex at 32'. Coax from rig goes to an ICOM AH-4 auto tuner at the mast base, then a 1:1 current balun, a dual spark gap lightning arrestor, then 450Ω window line up the mast. The tuner integrates nicely with the IC-7300 & matches pretty well. I've made contacts on all the HF bands with it. I think I'll try the short loaded dipole as a sloper (I have the coils). I can hang one end from the mast and anchor the other end to a ground stake. I can point it at OS & it should give me a little ground wave gain (at least that's what people write). If it has reasonable SWR, I can run separate coax into the shack & just switch to it for the net if needed. 73 Dave, VE3WI |
