keeping the IC-7300 theme going... - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: NEWS (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=23) +---- Forum: Opinion (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=48) +---- Thread: keeping the IC-7300 theme going... (/showthread.php?tid=379) |
keeping the IC-7300 theme going... - VE3WI Dave - 2021-03-09 A bit of trivia I found: The IC-7300 S-meter isn't calibrated the way you'd think it should be. John Akerman N8UR measured the meter response. His results are in the attached table. I included the so-called "Collins Standard" which is the way I thought most manufacturers calibrated their S-meters. (±1 S-unit = ±6 dB, S9 = -73 dBm or 50 µV into 50Ω). The IC-7300 is spot on at S9, but each S-unit change appears to be about 3 dB, not the expected 6 dB. Curious. 73 Dave, VE3WI PS: John's blog post is at https://blog.febo.com/?p=378 |
