Interfacing Tutorial - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: Operating (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=22) +---- Forum: HF Digital (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=39) +---- Thread: Interfacing Tutorial (/showthread.php?tid=460) |
Interfacing Tutorial - VE3WI Dave - 2021-04-30 If you are into digital and are having problems with your radio-PC interface, I found this link (in the 29 Apr ARRL Letter) to a presentation that might have the answer: https://www.kkn.net/~n6tv/Everything%20You%20Need%20to%20Know%20About%20USB%20and%20Serial%20Interfaces%20by%20N6TV.pdf 73 Dave, VE3WI RE: Interfacing Tutorial - Adam_VE3FP - 2021-04-30 (2021-04-30, 07:08:26)VE3WI Dave Wrote: If you are into digital and are having problems with your radio-PC interface, I found this link (in the 29 Apr ARRL Letter) to a presentation that might have the answer:Lot of good documentation in that link. I had some USB - CI-V interfaces for the Icom IC-7000 which worked in Windows 7 and early versions of Windows 10 but over time with different updates they quit working. I purchased another version using CH340T chipset vs FTDI and worked for quite a while but last summer I tried it and that one no longer works. There is a lot of interfaces out there but many are just knock offs of FTDI and will not work. So be aware. |
