New Antenna Tower - Printable Version +- GBARC Forum (https://www.gbarc.ca/ForumBB) +-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5) +--- Forum: Builders (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=19) +---- Forum: Antennas (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=12) +---- Thread: New Antenna Tower (/showthread.php?tid=996) |
New Antenna Tower - ryan_va3ryc - 2023-06-24 Hi Everyone, I am Ryan, VA3RYC. I am new to the group, and new to the area. I just purchased a home in Flesherton, and I'm looking to put up a tower for Starlink and Amateur antennas. This will be my first tower, and I was going to see if anyone in the area had some experience to share. I talked to the municipality, and I have it in writing that I do not need a building permit, and I plan to stay under 15m so I fall under ISED and not the land use authority. So I am close to ready for a tower. My ideal location is right next to the house, so that brings up a few questions. First off, does anyone feel strongly about concrete vs house-attached. Second, does that affect how I ground the tower (I normally would cadweld a new ground rod around and bond the tower with a clamp, but I am unsure being close to the house if I would need to tie it to the house ground too?). I also know that if I use concrete I probably need to deal with the leverage effect and make it the same depth as the foundation (which would be obnoxious and heavy) or I need to make a flex joint (which I have not done with concrete before). I'm also planning a hinge base, possibly a Wade: https://wadeantenna.com/product/golden-n...e-up-base/ because I can get a good deal on it. Any advice would be appreciated! 73 VA3RYC |
