GBARC Forum
Field Deployable Crossband Repeater - Printable Version
+- GBARC Forum (https://www.gbarc.ca/ForumBB)
+-- Forum: Amateur Radio (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=5)
+--- Forum: Operating --- Get ON the Air (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=22)
+---- Forum: Field Portable & Remote Operations (https://www.gbarc.ca/ForumBB/forumdisplay.php?fid=41)
+---- Thread: Field Deployable Crossband Repeater (/showthread.php?tid=539)
Field Deployable Crossband Repeater - VA3KOT John - 2021-07-23
I have resurrected and tested an old crossband repeater that could be deployed in support of GBARC/ACS events. It comprises an Icom dual band radio mounted in a rugged metal box and a Diamond X50A dual band vertical antenna mounted on a pole supported by a tripod.
The antenna has a manufacturer claimed gain of 4.5dB on VHF and the radio has a maximum power output of 50W. Together, the effective radiated power is therefore about 140W.
USE CASES:
1. Unattended crossband repeater for extending the support range during an Auxiliary Communications Service event.
2. Attended range booster for a repeater from a weak signal location
3. Allows repeater operation from inside a vehicle with a low-power handheld device during a field event
[Image: XBRepeater1.jpg]
[Image: XBRepeater2.jpg]
RE: Field Deployable Crossband Repeater - Tom VA3TS - 2021-07-23
Some further information on cross band repeaters from the March 2018 newsletter
https://gbarc.ca/archive/nl2018mar.pdf
