- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
Interfacing Tutorial
Threads: 98
Likes Received: 92 in 67 posts
Likes Given: 13
417
If you are into digital and are having problems with your radio-PC interface, I found this link (in the 29 Apr ARRL Letter) to a presentation that might have the answer:
https://www.kkn.net/~n6tv/Everything%20Y...20N6TV.pdf
IP Address: 173.241.106.237
Threads: 50
Likes Received: 63 in 37 posts
Likes Given: 22
294
2021-04-30, 10:15:22
(This post was last modified: 2021-04-30, 14:01:25 by Tom VA3TS.)
(2021-04-30, 07:08:26)VE3WI Dave Wrote: If you are into digital and are having problems with your radio-PC interface, I found this link (in the 29 Apr ARRL Letter) to a presentation that might have the answer:
Dave, VE3WI Lot of good documentation in that link. I had some USB - CI-V interfaces for the Icom IC-7000 which worked in Windows 7 and early versions of Windows 10 but over time with different updates they quit working. I purchased another version using CH340T chipset vs FTDI and worked for quite a while but last summer I tried it and that one no longer works. There is a lot of interfaces out there but many are just knock offs of FTDI and will not work. So be aware.
Users browsing this thread: 7 Guest(s)
